Lock washer
Tonyman
Car: 1990 nissan 240sx SE
so i just put my new suspension on my car and noticed the lock washers sitting on the ground after i had put it all together.
my question is, do you think its safe to drive on for a couple of days without that piece? i have work and don't have time to take the strut assembly apart for a couple days to put the piece in.
it makes a nasty sound when going over bumps. like metal hitting metal and i think the lock washer is the cause.
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Do you know exactly where the washer came from? The whole metal hitting metal sound doesn't sound good.
Shabbernigdo
pull it back appart and do it right.
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
what did you install coilovers or new shocks? the metal sound could be the strut assembly against inside shock tower. there is supposed to be a rubber gasket in their for noise. i just used a bead of silicone when i installed my coilovers
Ghast
Car: 1993 240sx, 2002 Lancer ES, 2006 350z Enthusiast
Pics?
MastaYu
Car: 92 Nissan 240SX SE HB
Tonyman
splintercell wrote: what did you install coilovers or new shocks? the metal sound could be the strut assembly against inside shock tower. there is supposed to be a rubber gasket in their for noise. i just used a bead of silicone when i installed my coilovers
you mean the gasket that was all broken from the original strut that i just threw back on there? that makes sense. i just installed new struts and springs. kept the original upper mounts.
ill try that silicone trick before i take apart the hole strut assembly to put that washer thing back in were its suppose to go.
splintercell
correct! that lock washer might go under neath strut nut in the middle of assembly.
Tonyman
so what kind of Silicone rubber should i use. Silicone rubber Caulk? or a different kind
splintercell
Tonyman wrote:so what kind of Silicone rubber should i use. Silicone rubber Caulk? or a different kind
that will work...i think i used rtv gasket silicone i had lying around. anything that forms a rubber consistency when hardened will work... ive never had a problem.
Tonyman
Thanks for the help Splintercell. im going to do that tomorrow. i dont want to have drive on it makeing that sound anymore.
vancouverbc
Car: 1991 240sx
i forgot to put the rubber caps on for the rear shocks and boy did that make a noise. the caps that you remove to expose bolts.
Suspension: Front StrutsSuspension: Rear shocks
Pictures
gasket(I used silicone)
[disassembled
Modified by vancouverbc at 3:22 AM 4/27/2009
Modified by vancouverbc at 3:24 AM 4/27/2009
splintercell
Tonyman wrote:Thanks for the help Splintercell. im going to do that tomorrow. i dont want to have drive on it makeing that sound anymore.
n/p vancouverbc has good pics of same thing i did
Tonyman
the thing i circled in the picture is the piece that i left out. think its important? haha
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
yes, it keeps the rotation of the shock from unscrewing the threaded portion on top of the shaft. put it back on.
Tonyman
ok so i put the lock washers back in and used the silicone as the gasket, but i'm still getting that rough sound. its quieted down a little but its still noticeable.
i had to go to school right after i got it done. do you think because i didn't wait for the silicone to harden that it might not have settled right?
any other suggestions on how to fix it?
splintercell
Tonyman wrote:ok so i put the lock washers back in and used the silicone as the gasket, but i'm still getting that rough sound. its quieted down a little but its still noticeable.
i dont think that would have made a diff. I ditched my stock susp for coilovers as soon as i got the car so i never fooled with oem stuff.
