DJ_B_Easy »
https://forums.nicoclub.com/dj-b-easy-u152144.html
Fri Jun 22, 2012 6:56 am
^Right, the set he linked to does not have the 4 locking lugs per set (1 per wheel), it has 20 lugs that are exactly the same and only require the patterened socket.
I consider locking lugs to be the ones requiring an actual key, not just a patterened socket. If someone wants to remove your patterened lugs, they are going to do it with or without the patterened socket. Even the ones that require an actual key can be removed if somone is determined enough. They may slow them down, but if they want them they can get them off.
