slw240sx wrote:well i have a non options 240 an i have the pwr lock pwr window doors! so ill have all the wires on that side of the harness i was wanting to know if the body harness had the connectors, or are you saying that it only has the speaker wires on the body harness
If you have the doors, then it might work, not sure on S13s though. You would still need the door lock timer and add any fuses/relays neccessary to make it work. Since you have the doors, you could do all your own wiring anyway, tying into the windows won't work because the windows are ignition powered, not constant. Just use a standard SPST relay, and use the switch to trigger it. I'd draw a diagram but I'm tired.
