laloba314 »
https://forums.nicoclub.com/laloba314-u44020.html
Tue Jul 25, 2006 5:53 pm
Well, I replaced the water pump, tonight. I have now replaced the whole cooling system, basically. And I learned some things that you guys probably already know, but here it goes anyway!! I jacked the front end up, replaced the fluids, bled the the system while running the car with the heater on full blast and now my car isn't overheating! I had originally blown a hose, this is where it all started, I believe that if I had bled the system the way that I did tonight, I would have saved my self almost $300. I just hope that this will help someone else not have to go through all the trouble and the expense that I just did.
