Location of the SR20DET ignitor chip
90S13dude
Car: 90 240SX SE
Can anyone tell me where the SR20DET ignitor chip mounts? I am trying to lacate it before I call the company I ordered from and start yelling.ThanksChris
Fenvy
Car: 2005 350Z Base 6MT
isn't it mounted to the passender side fender tower facing toward the motor?
90S13dude
Car: 90 240SX SE
I really dont know I guess I should have gotten a front clip. So it doesn't mount on the motor anywhere? Guess I will call the company in the am.
sbanzer123
Car: 95 s14
us passenger side near the windshield wiper motor.
90S13dude
Car: 90 240SX SE
are we talking on the firewall? Cuz if so I do not have a clip.
Fenvy
no, it is mounted on a brass bracket, which is then mounted onto the strut tower. It is very close to the winshield motor thingy
Blown240sx
Car: 1996 240sx
If you didnt order a clip then it should be on the Wiring harness somewhere. It looks like a Small pentagon shaped with two plugs and on one side 5 wires on the other 4 wires
sbanzer123
Car: 95 s14
this is where is was on my s14 front clip. it should be placed in relativly the same spot on a s13
DuckyD
Car: 1995 240SX
If you need to order a new one, you can get the Ignitor Chip out of a Suzuki Sidekick (Part #33370-77E20). It works. And it's cheaper.
Here is where mine is located. It sits loose.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
i dont think you have the right part in mind. i dont see an ignitor in your pic.
sbanzer123 wrote:this is where is was on my s14 front clip. it should be placed in relativly the same spot on a s13
sbanzer123
Car: 95 s14
its on the same bracket as the factory boost solenoid. thats what your looking at.
sbanzer123
Car: 95 s14
correct me if im wrong
90S13dude
Car: 90 240SX SE
Would that be on the side mount??? That's all that it came with. I have the two plugs on the harness but nothing connected to them. Where would I find the factory boost solenoid??? Is it on the motor???Chris
sbanzer123
Car: 95 s14
my clip was pretty much stock with the exception of a hks suction filter. so it did have the stock sidemount. it should have nothing to do with an intercooler.
90S13dude
Car: 90 240SX SE
No, what I am saying is where would the factory boost solenoid be mounted? I realize that the intercooler has nothing to do with it. I am trying to find out where this is located. As stated previously I found both ignitor plugs but they were connected to nothing.Chris
sbanzer123
Car: 95 s14
its mounted in the first pic i posted in the red circle.
srpowered240sx
mines located here too. its not attached to the motor stock so a cheap motor set possibly would not come with one. if i recall, q45 chips will work, and so will z32 chips; both will probably need a little wiring work.
DuckyD wrote:If you need to order a new one, you can get the Ignitor Chip out of a Suzuki Sidekick (Part #33370-77E20). It works. And it's cheaper.
90S13dude
Car: 90 240SX SE
I called the company and they shipped one out to me. Thanks for the help though.Chris
