Location of the chime module - warning buzzer
alexlloyd
Car: 1995 Maxima
My 95 Maxima has no warning buzzer. Powered by fuze 40 (7.5) and grounded by the BCM for all functions but I have no idea where it is. Anybody know, I am suspecting the command start installer disconnected it rather than trying to bypass it when running on command start. I am assuming it is up under the dash somewhere but any assistance would be greatly appreciated.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
If it's like a '93 240SX then it's in the drivers side fuse box near the kick panel. On the 240 it's a white box with a harness plugged into it. I didn't have a buzzer but it turns out that the previous owner had uplugged it and taken out the fuse...problem solved.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I can't tell you off the top of my head, but I'll be at home where I can check the FSM in about 2 hours. Check back around then and I should have an answer for you.
EDIT:Unfortunately, I can't find the location. Hopefully someone with a 4th gen can chime in and help you there. Sorry.
alexlloyd
Car: 1995 Maxima
I guess I should have stated that the FSM didn't show me...
maxhopper
Car: 02 Maxima SE 6spd
Sure it does, just have to know how to make it tell you. If you'll check out page EL-290 that will show you the main wiring harness. Connector M35 is the warning buzzer. It looks to be in the area of the ECU.
alexlloyd
Car: 1995 Maxima
It most certainly does, thanks I appreciate the help; I was going crosseyed.
alexlloyd
Car: 1995 Maxima
Found it thanks, exactly as I figured, whoever installed the command start disconnected it ans tied the lead up with the command start wires.
