WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue Mar 23, 2004 4:11 pm
Looking at the engine from the passenger side of the car, look at the fuel rail, its just on top of the intake. You'll see the 4 injectors and the wiring for each. On the side of the fuel rail closest to the fire wall, at the end of the reail, you'll find the fuel pressure regulator. It will have 2 lines coming off of it. One is larger, thats the fuel return, the second is the vacuum. For you to T off of.
If you still have trouble try this. Find the fuel filter. There will be one line coming from it. Thats the supply line. There should be a return line running next to it to it up to the intake. Just follow the lines. Hope that helps.
WD
