Location of ECM?
rainerng
Hi, the ECM is located "at the driver's side strut tower"....can anyone tell me where exactly that is? Is it right above the clutch pedal?
jfanaselle
Car: 2007 Nissan Versa Hatchback SL, 2008 Nissan Rogue SL
Yesterday, I was running wires for my stereo setup and I found my ECM while I was getting through the firewall. It's actually under the hood. If you look from the front of the vehicle (with you standing in front of the car looking under the hood), it'll be on the right hand side of the air box facing sideways (it's actually bolted right to the strut tower perpendicular to the firewall). You need to remove the battery, then the air filter box to get to it. Then, there are two nuts (10 mm if I remember correctly) that need to be remove and it slides right off of the two bolts. Hope that helps!
reyes1212
Car: '07 Nissan Versa Super Black
What are you planning to do?
rainerng
Get the tach wire for my remote starter install
