95_Max_Wreck »
https://forums.nicoclub.com/95-max-wreck-u267467.html
Tue Aug 30, 2016 7:34 pm
^^ Indeed...I agree.
But I have updated information on the 1994 Sentra with the manual heater control panel, not the "push control" panel.
There is no relay in the power circuit. Since power actually flows from the negative to the positive, Nissan designed the circuit according to that, which is opposite of what other designers might do.
From the dual 15 amp fuses, the power goes directly to the fan motor, from there to the resistor pack, and from the resistor back to the speed control switch, then to ground. With the motor unplugged, there will be no voltage anywhere on the circuit. And there is nothing in between the fuses and the fan motor but a wire with a 30 amp capacity.
So the motor on this car obviously had a shorted armature, drew too much current and blew out the Speed 1 resistor circuit, which makes sense because that's the highest resistance in the pack. So are replace the motor and the resistor pack from a junkyard, and the system works like brand-new.
By the way, the HA section of the service manual told me what I needed to know in order to trace that circuit.
