Load Sensor ID + Locations
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
hey wassup guys. just wanted to know the location of all the load sensors on an S13 blacktop. i know where the MAF is as well as the TPS, but in particular im looking for the MAP sensor for engine testing purposes. i dont know if SR20s run a MAP if there is already a MAF sensor present. if there is no MAP sensor, what signals the computer to increase fuel and spark during heavy engine load or high engine speeds?
karmakaze
Car: 98 240sx SE
jdm_master_X wrote:hey wassup guys. just wanted to know the location of all the load sensors on an S13 blacktop. i know where the MAF is as well as the TPS, but in particular im looking for the MAP sensor for engine testing purposes. i dont know if SR20s run a MAP if there is already a MAF sensor present. if there is no MAP sensor, what signals the computer to increase fuel and spark during heavy engine load or high engine speeds?
the sr does not run a MAP system. so there is no MAP Sensor. The signal from the MAF and O2 sensor is what it uses to calculate air/fuel ratio.
