Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Fri Mar 26, 2004 11:24 am
meaintining the lod rating on a heavy vehicle is very important, if you lower the load index signifigantly, you ususally ahve to incresse the air pressure to meet the load bearing requirements of the MFR, ie a 32 psi on a 95 load index tire amy mean if you use a 93 you'll need 35-38psi, etc....
I would keep it as close tos tock as possible, if not greater.-chet
