LMGT4 - Anyone on the Coupe?
All things Altima Coupe.
LEMboy9
Car: 2008 Nissam Altima Coupe
Has anyone bought the LMGT4 rims and put them on a coupe? I have been looking online and have not been able to find anything about what I would need to do in order to get them on my coupe.
thanks-Beck
JDRosenberg07
Car: 08 Altima Coupe 2.5 6MT
You only need to know the bolt pattern and size of the wheels. 18's and 19's should fit no problem. But the bolt pattern needs to be 5x114.3 or 5x114 (it's the same thing) if it's a different pattern then it won't work unless you spend an extra $100+ on wheel adapters to change your bolt pattern. Hope this helps. Good luck and post some pics of the wheels
LEMboy9
thank you
I was really hopeing to see what it would look like with the different offset.
I am looking at getting Bronze 18's with a 25mm offset.
Bmore-coupe
Car: 08 Altima Coupe 3.5
LMGT2 FTW if you can find them! super rare!
I love LMGT4 as well. I saw a set on ebay a few months ago.
As said above, make sure to check the bolt pattern, I cant remember off the top of my head if they will fit the coupe.
LEMboy9
LMGT2
Yeah, I found a set of the LMGT4's for 800 (Bronze) but they are a +25 offset and I have yet to find anyone with that on an Altima Coupe. I am just worried about the look. The bolt patter is right, and they are only 18" so I just need to figure out if the offset would be alright.
JDRosenberg07
stock offset is 45 if i remember correctly. so they will probably be sunken in more than the stock wheels. if you want it to be flush with the fenders you should still get adapters, you can get these with the same bolt pattern. spacers are not safe past about 10mm but adapters you can go past 25mm and be okay.
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
JDRosenberg07 wrote:stock offset is 45 if i remember correctly. so they will probably be sunken in more than the stock wheels. if you want it to be flush with the fenders you should still get adapters, you can get these with the same bolt pattern. spacers are not safe past about 10mm but adapters you can go past 25mm and be okay.
^ You got it all backwards man! A wheel with a 25mm offset will sit further out than the stock wheels. The LMGT4, being a wider wheel with an offset 20mm less than stock, may stick out a good bit from the fender.The LMGT4's probably won't fit the car in stock form. to fit the wheels, you'd have to run a lot of camber or roll, and maybe even pull the fenders.
JDRosenberg07
I stand corrected..lol
to myself
LEMboy9
Hey thanks guys!
I am still on the search to see is anyone has actually tries these yet. I just don't want to be spending a good chunk of change in order to find out that the wheels won't fit/look terrible.
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
25mm offset? i'm on g35 rims which are 19x8.5 and 33mm offset and my wheels are REALLY flush with my fenders, 25 offset would stick out for sure, but i've heard that with our cars even if they stick out, they don't rub. someone else was running 25mm offset and lowered on eibachs with wide rims and said he didn't rub. but i've heard of a lot more people say that they rub when the have low offset and not even lowered, just be careful on any dips and bumps i guess
LEMboy9
Yeah, I really don't want my wheels to stick out past my fender. I have seen a few cars that have that done and I think it looks funny. (IMHO) I guess I will have to wait and see if another set comes my way that is closer to a 33 or 35 offset. I also came across a set of 17" OEM rims from an 04 350z that I may get since the LMGT4's seem to not be working out. The guy said he'd take 175 for the set.
mattybo
Car: 2009 Altima Coupe 3.5 SE - Precision Gray
LEMboy9 wrote:Has anyone bought the LMGT4 rims and put them on a coupe? I have been looking online and have not been able to find anything about what I would need to do in order to get them on my coupe.
thanks-Beck
http://www.neweraparts.com/Def...D=286
This site has them in any size/offset and bronze or silver...800 bucks for all 4 not including shipping from the UK...
EDIT: My mistake it is 800 per rim...oops!
Desire1314
Car: Altima Coupe 3.5SE 6MT
so did you decide to go with these wheels yet? i was gonna get them in bronze, but i decided to go with volk again. top secret gold
LEMboy9
I don't want to buy them unless I can find a 35mm offset. the 25 would look terrible and that's all I can find for now. I did however pick up a set of 17" OEM 350z wheels that I will be riding on during the winter. I am hopeing that they will look good until I can find a set of the LMGT4s that will fit and not completely bankrupt me. I have been trying to find a picture of another altima with the stock 17" 350z wheels but haven't been able to. hopefully they'll look good.
Desire1314
umm i think its stickied at the very top of the forum with A/C's in all different kinds of wheels.
LEMboy9
Yeah I'm not seeing it. I tried searching for the wheels as well to see if anyone had put them on, but the only thing I keep coming up with are Maxima's
