when i was helping jookmasta tune his car. i made an educated guess off the boost and turbo size to get a rough idea of a rich setting that i could go off of first when we rolled on it.
i belive he is running a t3 60trim, 370cc injectors9psi
NA- -27 across the board.
then i guessed:
1k- -22%2k- -10%3k- -5%4k- 0%5k- 0%6k- 0%7k- 0%
i belive we left the safc throttle settings at 20%, 40%. we went about 3\4 throttle, and i saw a 12.9 afr at 4k so i told him to stop. then i made adjustments accordingly where fuel was needed and went at it again.
we were running out of time and should go back to "fine" tune the low throttle map. but 50 mins flew by so quickly.
we were using "willfastbackse's" innovative lm-1 wideband.
i belive the start up instructions are in the box.
if you want to talk to me about it, and get some suggestions, email me
[email protected]
