300max »
https://forums.nicoclub.com/300max-u6201.html
Fri Apr 16, 2004 8:09 am
What I meant by rpm tag was that the afr would be displayed graphically on the computer but at the same time it would reference it not only by seconds but also by what rpm the vehicle was at and or what the throttle position is. On the Lm-1 website it has lines plotted and displayed on a computer. They also have the vehicle's rpm, dwell etc plotted right alongside the afr ratio.
Also how do you use the afc to control the afr if you only know what the ratio is at 10 seconds into the record time as opposed to what rpm the engine is at. I'm not sure if I'm making sense here.
