SSS »
https://forums.nicoclub.com/sss-u3929.html
Sat Jan 15, 2005 12:30 am
Thanks for the help devious, the car actually did start with a stock KA map about 30mins after i posted this, i'm 99% sure that the romulator socket came loose (i had the lid of the ecu on with the romulator unit attached to the other side).
However, live edit has some small problems with the KA, the main one being rev limiter errors if you decrease/increase the limiter, change to another map then switch back. I have contacted lawrence about this, but have got no reply.
The car does seem to run rough-ish on a stock map compared to my stock ECU that lives in the car. The ECM light also comes on when changes are made to the map whilst the car is running.
