Live Edit - Final Release
c-rad
Car: 1991 Nissan 240SX w/CA18DET
I just added it to my site- http://ca18det.escic.com
The author of the program finally did an update to the beta version. Some bugs were fixed and a few things were added.
datsunboy
Car: Datsuns
you should add his new software to your site too then?He has stopped working on Live Edit, and is now developing NRE ( Nissan Realtime Editor ).he has released the first verion of this on his website.
c-rad
datsunboy wrote:you should add his new software to your site too then?He has stopped working on Live Edit, and is now developing NRE ( Nissan Realtime Editor ).he has released the first verion of this on his website.
Yeah, but its not free.... its like $500. Not to mention the emulator you need to use with it is $1,300.
originalsin
d/l'd it, and i uploaded the 440cc/z32 maf but in the program it says ca18det maf? shuld this be changed or is it alrdy set? and i will actually be running rb26 444cc injectors, will it still b fine?
datsunboy
Car: Datsuns
yes it is free if you dont want to use an emulator.you only have to pay to register it IF you want to be able to emulate with it....
c-rad
datsunboy wrote:yes it is free if you dont want to use an emulator.you only have to pay to register it IF you want to be able to emulate with it....
Wow, it's pretty cool. Too bad its so expensive and incompatible with the Xtronics one. I like the interface a lot though. Much nicer than Live Edit. I'll add it to the site.
originalsin
crad, answer to my question?
c-rad
originalsin wrote:crad, answer to my question?
It should have been picked up. But if not, I would just get a stock rom and modify it to your specs. Try out the NRE program. It has a little nicer interface than Live Edit.
originalsin
no no i was mainly asking if the 440cc map will b ok for 444cc injectors, i mean they are only another 4cc...but just wanted to make sure
c-rad
originalsin wrote:no no i was mainly asking if the 440cc map will b ok for 444cc injectors, i mean they are only another 4cc...but just wanted to make sure
Should be fine. But even still, the NRE program, you just enter in 370cc for the stock size, then 444cc for the new size, and it automatically makes the adjustments for you.
