little worried :(
ss240
guys...
I'm a little worried that i've been doing all this work and its not going to fix my problem
... I had the good old white smoke POURING out of the exhaust after I pulled one of my injectors to take a look and cranked the engine while the injector was still out.
So a combination of opinions led to the idea that it was the head gasket. While ripping apart the engine I found my spark plugs COVERED in oil.
however, when i got down to the head gasket... to be honest.. it looked fine...
(pics at http://photos.yahoo.com/craigods)
Can anyone here take a stab at reassuring me that it still can be my head gasket :P?
I'm picking up new head bolt washers from the dealership tomorrow and from there I'm going to continue reassembling this beast of a ka24de.
thanks for everyone here at NICO for their continual support in all our quests for keeping our cars running
[s3]
Pics are not close up enogh, take a close inspection of your head gasket, even the smallest dent, fray, detachment will make it leak.
Oil covered plugs are either worn rings, worn cylinder walls or a combination of PCV valve failure causing the oil to be forced into the combustion chamber..all of which are bad.
Do a compression test to eliminate the possibilities.
Chezedik
Car: 1991 Nissan 240sx
Do the head holts not get replaced on a KA24DE? Because I can not find them.
pmkls2
Car: 1990 240SX Fastback
Well, you answered your own question sort of. A leaking head gasket is not likely to cause oil to leak into the combustion chamber. However, having said that, you really need to check the valve stem seals and guides. Honestly, if you already have the head off I would strongly suggest replacing the valve stem seals reguardless of how they look because hopefully for your sake it is going to be a very long time until you remove the head again..... Check the guides also because although I am not too familiar to nissan heads in particular most japanese aluminum heads didnt have very durable valve guides as they are just part of the aluminum casting. But like was mentioned earlier the most likely causes for oil getting into the cylinder are rings, cylinder walls, pcv valve, or valve seals and/or guides.
pmkls2
p.s. reguardless of what the true problem is, you would have most likely had to remove the head anyways to fix it..............
frapjap
'07 Subaru Legacy
Was this problem ever resolved? Can someone let me know what was done. I am having the same crappy issue.
nab911
Car: 93 Nissan 240SX SE
I am too but my problem is blown turbo.
sanioll
Car: Nissan 240SX SE
Toyota Camry
i really hope that you can put that engine back together
really hope, that you have complete service manual
frapjap
'07 Subaru Legacy
So no resolution yet??
