Little Wiring Help
dpomerico
So . . . when I got my vert my buddy already did the SR20 swap, but it seems they FUBAR'd the wiring pretty good.
Been trying to get the reverse lights and the top to function and came to find out the Blue/Green wire that should be the constant voltage has no power to it.
Any idea where this runs from or what the voltage is? What I found in the FSM didn't help much. Can I just wire power to the Top and the Reverse lights from another source? Thanks in advance guys.
240vert93
read the auto to 5pd swap info. It should clear everything up for you
dpomerico
I did I have it printed out in front of me =D The problem isn't the wiring it's that the Constant Voltage wire has no voltage on it.
240vert93
I would say fuses then. I know there is also a fusible link somewhere but have been unable to find it.
dpomerico
Yea thats where I was lost. I found the fuse for the reverse lights and it was good. I even replaced it just make sure. Thats why I'm wondering if maybe the wire got cut when he did the swap or if he forget to hook it up someplace.
I work with electrical systems by trade and it sucks not having a full blown schematic for something.
dpomerico
Got it fixed. It seems . . . I was blowing the fuse whenever I was putting the top up for down. I had a loose wire on the back of the fuse that was shorting out blowing the fuse. Thnx for the help 240vert93. Tell you what though that fuse box is a ***** to work around.
