hksdrift240 »
https://forums.nicoclub.com/hksdrift240-u143017.html
Sun Oct 18, 2009 12:45 pm
I've got a 95 nissan 240 5spd with about 164k miles on it. Its starting to get cold here so i need heat, but i found out i dont have any. The temp gauge reads in the middle. I thought it could be the thermostat, so i replaced it...it seemed to help a little, but not like it should. I let it run after replacing the thermostat, and after it ran for like 10-15 mins, I took it down the road (at this point, the radiator was full, and the cap was on) and came back and let it idle for about 5 mins and the temp gauge started going up and got almost to the H mark and the heat actually felt like it should. I cut the engine off cause it kept getting closer to the H, and when I started it back up, the temp droped back down to normal, and that nice heat left too. I felt of the 2 hoses going to the heater core and both were really warm, but not to the point you couldn't touch them. It almost seems that the engine itself isn't warming up enough. I dont really know what to do at this point. I thought about reverse flushing the heater core, but seeing how it put out really good heat when the engine temp went up, It seems like its ok.
