little problems that bug me.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Ok #1 my spedo?!?!?!? I'll start driving after it's warmed up and it will just peg itself? then out of no where maybe 15min down the road it goes back to normal? anyone ohave this problem?
ok #2 This has only happend a few times. Key goes out but dash lights stay on or they go off and there is power going to the alternators voltage regulator??
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
check your charging voltage. Sounds like its maxing the regulator out.
As for the SS sounds like you have an internal short in the sensor itself to ground which will cause it to peg. If it doesn't peg while not in movement than its def your SS, but try jiggling wires and have a friend to see if the speedo jump.
I've heard of people complaining about the key out still on problem... search its somewhere I think they said it was a mis-wiring problem.-Alex
Yellow4g63
Tried searching for it but couldn't find it. I remeber seeing it a while back. I was working alot of hours last year and couldn't get to it.
