no all the stuff is just stuff i did so far motor wize but while i did the transmission swap i did the water pump, thermostat, becuase my engine would overheat alot, turned out it was a huge air bubble inside the cooling system, but thats fixed now, and also the alternator cus the original one just died.liquid_cool wrote:did you only do a transmission swapp when this began to happen to you?...or did you have all the other work done before initial start up?
i actualy just got a stop fuel pump, but now that u mention it i notice i am burning alot of gas, i put half tank of gas 2 days ago and now am almost at empty and i only go from work to home 10 minutes away. and i am also using stock ecu the auto one since i read that it makes no difference but i did manage to get the reverse lights to work now it was just bad wireing.Z-tune! wrote:did you do an aftermarket higher flow fuel pump? if so, you might need an adjustable regulator. otherwise, you're flooding your engine with too much fuel, and could explain the running condition and shutting off. also, check your maf, maf wiring or make sure its plugged in. it sounds like it's either in limp mode or dumping too much fuel. lastly.. i dont know too much on this part of it, but are you sure youre using the right ecu? that could explain alot of things all at once
by 'transmission swap' i was assuming a/t to m/t. correct me if i'm wrong
i do have some other injectors that i have i will try it out but i actualy don't have no engine light on.locoluna825 wrote:sounds like exactly what my car was just doing last week, mine also acted up pretty bad after the manual swap. was always there but barley noticeable just got worse after the swap, i had an injector leak i changed the seals thinking it would fix it NOPE made it worse. Fuel started leaking out of the body of the injector real bad, ended up buying a set of remanufactured injectors for 100 bucks and they got a 5 year 80,000 mile warranty. fixed it just 2 days ago but the idle was still bouncing like yours and almost dying when i pressed the clutch in. That is until the engine light cleared, then it was all better runs beautiful now.
Modified by locoluna825 at 4:44 PM 8/10/2009
i only wired the reverse light witch now work and the to wires that are jumped to make the car start. thats it.locoluna825 wrote:its his fuel system you cant wire the manual trans to the auto ecu you just leave it unplugged at the fuse box as a matter of fact don't even try wiring anything else but the speed sensor and reverse lights, and the neutral safety switch jumper.
the car was running excelect after the fuel pump, problem occurd after the transmission swap, i am alittle mechanicly incline so for me its usualy easy to tell what a problem is but this one its realy got me. i have checked almost everything from fuel to electrical and can't seem to find anything, i still have to change the injectors i will be doing this weekend just trying to see if i left something out so i can also work on it on the weekend.Azrial wrote:You could have got a bad fuel pump. Sometimes these things happen.
i actualy changed 3 different maf's and the car still the same but now that u mention it i have not even tought about the TPS i will do that today, and yea i do plan to change everything i am just working out the kinks on this car first becuase the previous dushbag owner did not know s*** about this car and said he was gonna put a supra engine on it lol wired everything with masking tape instead of electrical tape, but so far all that stuff is fixed already. i will let u guys know the outcome of the TPS. thank you.liquid_cool wrote:have you tested your Maf and TPS?..if not do that..this could be an issue with those 2 or one of the two...what breally is bothering me thou..is your using the auto ecu and harness...you should do a full swapp and locate a harness and ecu aswell..this will eliminate allot of head aches later on if ya decide to go ka-T in my opinion..let us know updates.
