eagent »
https://forums.nicoclub.com/eagent-u4880.html
Sun Feb 09, 2003 7:04 am
Good morning, gents!
OK, with the great success of the Stumbling Q, I'd love to have your input on some of the less mission-critical issues with the car. Ready?
1) The sunroof has recently quit rolling. One day, it rolled back, and then the motor sounded like it was freewheeling. I had to hand-slide the thing forward to 98% closed position (the internal panel is closed, but the roof portion is not seated, and still has a 2/8+ gap at the rear of the roof, where it would normally seal). The motor runs forward, but there's no apparent grip on the sunroof panel.
Is this like Mercedes, where there's a cable assembly, and you have a crank in the trunk to manually drive it closed? Or is there a sprocket up front (under the courtesy light cluster) os anything? Just curious.
2) I've read tons on the Bose Stereo issue. My problem is the squeeling, "oh my God, what the heck is that alarm" sound in the rear speakers, sometimes the driver's door speaker.
I've disconnected the power to the rear deck speakers, but not the front (they operate most of the time, with some intermittent operation on the driver's door speaker). I have an electronics background, and can handle a soldering pencil with ease, and read resistor and capacitor codes... but it it worth it?
I've heard it's just a corrosion jump on the circuit board. If so, that what about just flooding the thing in spray contact or circuit board cleaner? Any success with that (I've removed the rear circuit boards, so this would be an easy fix).
3) The dash vinyl and pad, just to the right-center of the main instrumnet cluster, is slightly lifting. The vinyl and pad are intact, and still in great shape (no checking or cracking) but have lifted about 3/8th of an inch for about 6 inches. Is there a successful solution to regluing this, or do I need a dash replacement (yikes!)?
4) The steering has started feeling "mushy" as it turns, and there appears to be some delay and loss of specific pointing ability between when I turn and when the car turns. I do hear what sounds like a pump whine on the driver's side of the car. Not extreme, and not very high pitched, but evident (I've heard it on other Nissan cars as well, so thought nothing of it). It doesn't drift when I drive, but there seems to be a slight delay between turning the wheel and the car's response. Any ideas?
I think that's about it for this missive. It's amazing to me that this machine can have 163,000 miles on it, and still run like a top, drives like a dream, and I love the look and feel. The no-grill makes it look really refined, and I have the chrome 5-spoke flat wheels on it, giving a nice finish to the package (it's the champagne/silver color, with tan and brown interior and the aftermarket wood accents on the dash and doors).
Thanks again!
best,ME
