riaazfr1 »
https://forums.nicoclub.com/riaazfr1-u187340.html
Tue Jul 26, 2011 7:09 pm
You are going to need to get connectors from an auto store. what you are going to do is find where u want to tap the the washer jets into. for instance if u want to tap their lines into the main headlights or the park lights. to find out which wire carries the power to your park light/headlamps you will have to turn the car on and turn on your lights. take a voltage meter and test the lines to see which ones have power running through them. after you find the correct wires, shut the car off, cut the wires and strip them. use the connector to join the wires from your jets to the park light/headlamp wires
Hope this helps
