compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Tue Mar 27, 2012 11:21 am
Im running a 10mm spacer with z wheels and fit fine. As far as the subframe swap if your worried about the bushings just switch the diff and axles burr from what I hear as far as dd its strictly a noise issue when switching to solid bushings. Switching to a s14 subframe will allow you to run larger oem sway bars like a j30 or 300zx tt sway bar because its wider. Other than that, no huge benefits. When you do the 5 lug in the front, you have to use the s14 spindles, no option there (and its easier that way) i.only needed spacers inn the front, the rears clear just fine and I'm on the wider tt z wheels.
