little help on throttle body vaccum lines
josephg15
Car: 1992 240sx
ok so i saw this website a couple of nights ago and it was explaining what each nipple on the sr20 throttle body went to...for instance top on went to fpr...bottom on capped off...and it was explaining that the wastegate shouldn't have a (tee) on it...so anyways if anyone can help, thanks
SpeedRacer1
Car: 1990 240SX, G35
hkssupratt1994
Car: 92 240sx hatch
whats that little thing that the wastegate line goes to on the far right
SpeedRacer1
Wastegate valve solenoid, you can bypass it if you want to.
josephg15
Car: 1992 240sx
i have that one...by that wasnt the one i was looking for...i read it on a site, it wasnt an actual picture...but thanks though
SpeedRacer1
That diagram is all you need, if you get rid of a TB line on your car, just cap it. If you get rid of the wastegate solenoid, run the line from the wastegate directly to the cold pipe.
josephg15
Car: 1992 240sx
well ill just post my problem...my bov is on the cold side right before the throttle body. i have a nipple on my hot pipe...so i was thinking correct me if im wrong...
- my boost gauge gets its vaccum from the throttle body- my wastegate is connected to the nipple on my hot pipe...- my bov is connected to my throttle body- and my fpr is connected to my throttle body.
i am not to sure about the wastegate to the hot pipe?
let me know what you think, thanks joe
SpeedRacer1
Wastegate gets signal from the IC piping. FPR, boost gauge and BOV get signal from the same TB port. Cap the other two.
josephg15
Car: 1992 240sx
ok good..thanks that what i was looking for...thanks, joe
