KaDrifter »
https://forums.nicoclub.com/kadrifter-u8587.html
Fri Feb 27, 2004 3:12 pm
I work at Lake Nissan as a tech well I have this 03 Frontier that I'm working on that has a water leak problem. I found out that it leaks water on the passenger side only when the fresh air duct is open. I pull out the glove box and the micro-filter cover and there is water in there. So I think it is the A/C drain blow it out and water drains out through the drain so it is not plugged. I have taken out the blower motor water every where in the box. I have yet to take off the bottom half of the blower motor box and the heater core box, didn't get a chance to finish it today to many cust waits. I have yet to call the tech line to find out if this has happened before. Any help would be appericated.Thanks
