little help needed here!
rpm91240
Car: 91 240sx
please does anybody now how find out if the igniter chip is bad
need2drift
Car: 89 s13 sr20det powered coupe
If you know someone else with a sr just take theres out and see if it works in yours.
Nicksemianiw
Car: JDM 89 Silvia K's
Check if the ECU is throwing out any codes
rpm91240
Car: 91 240sx
what can i use to get the codes and whas' t the code for a bad igniter chip?
thanks alot apreciate the help......
Nicksemianiw
On the side of the ecu there are blinking lights and they will have codes beside them like a1 a2 a3 a4 and you just have to find out what those codes are for they will be blinking.
rpm91240
Car: 91 240sx
hey i did check for a blinking light on the side of the ecu but only see a red light. u now what that red light means
the light turns on when the swicht is open
