little help here
ca240sxcoupe
Car: 1989 240sx w/ca18det, 1978 Datsun 280z
hey guys got a question..just bought a t25 from an sr and i do not want to tap into the compressor housing to get a vacuum source for the wastegate. is there anywhere else to pull vacuum from? ive heard of using the line behind the throttle body, were people pull there vacuum for their bov....
the other thing is i am using an sr sidemount with a bov attached so if i run the vacuum for the wastegate into there were do i get vacuum for the bov
damesta
You should be fine running them from any vacuum source. I usually run them both from the big port on the side of the intake manifold.
ca240sxcoupe
so if you T off the source and then have them both run from the intake manifold it will run ok?
