USC Justice »
https://forums.nicoclub.com/usc-justice-u34663.html
Sun Jun 22, 2008 4:21 am
Do you have access to a lift, or are you working from jack stands? If you are working from a lift,it is much easier to pull just the transmission. If working from jack stands, I would pull the whole assembly and then separate. Pulling the entire engine set from the jack stands set up can be done in about 3 hours by yourself. With buddies and beer (after completion of course), it should be less than a 2 hour job. At least that's what I have been averaging.
Don't know what to tell you about the KA transmission swap, I have read about it, but never done it.
Hope it goes smoothly.Donald
