Neil »
https://forums.nicoclub.com/neil-u15642.html
Fri Feb 17, 2006 7:00 am
the clicking is from the solenoid for your boost controller. read the manual where it says "its normal to hear clicking from the solenoid".
And assuming you both have Profec B-II's, you did mount the solenoid using the rubber dampers they gave you, right? I have mine mounted closer to the fender on one of the 2 nuts thats for the original spark coil. with the rubber washers in place its not that loud but i dont even mind it anyway.
about fluctuating boost on high tho that happens to me some, when Im flooring it and let off a little it sounds like the turbo spins up faster. im not sure if its the solenoid bypassing pressure and the turbine is spinning more freely or what... play with your gain in +2% increments and see what happens. My start boost (set gain) is set at something like 11. i forget. its low cuz i have a sidemount but it says ive spiked to 12.7psi before.
