Since they are sooo tiny they are all built to gold standard. I forewarn you that most autoparts stores only stock 1 or 2 so you'll have a little trouble finding em. They are rated at 370CCA. Switching from the standard S13 battery to the Miata sees my SR ever so slightly harder to startup. This difference might be exaggerated once it gets cold though. The Miata battery will run you like $91 bucks after tax.hpmachine wrote:I heard they were decent. How many cold crank amps is it?
why piss your money away when you can have something that works just as well for much cheaper? I just find it ironic that you chastise people for cheaping out when you could have popped for an odyssey.Tulsa_S-13 wrote:I still don't understand why the **** 240 owners are so damn cheap.
"I have an SR that cost me xxxx.xx so I'm going to put a ****ing lawn mower battery on it! YEA!"
I also love seeing other people's battery relocation. Makes me sick.
My Miata battery has about 375cc which was just about the same as my old battery. Ryon, I have no clue what you're talking about regarding it taking longer to start. Mine starts just the same as it used to, lightning speed start-up.
I'd expect an electrical engineer to know that all batteries aren't created equal. Besides it was an ever so slight change that "might be exaggerated by the cold." Find a surprise in your cheerios this morning?Tulsa_S-13 wrote: Ryon, I have no clue what you're talking about regarding it taking longer to start. Mine starts just the same as it used to, lightning speed start-up.
The only lawn mower batterys we have here do not have the correct terminal post to use in a car. I bought my Miata battery because it fits by my intercooler piping with out any problems. When it comes time for me to relocate my battery I'll opt for a dry cell, probably Optima Red.whoflungpoo wrote:
and what about other people's relocations make you sick?
Waffle Crisp!redtop91 wrote:Find a surprise in your cheerios this morning?
Hey where did you get the odyssey battery at? Does it fit fine with the sr20 swap with a front mount, if you leave it up front?T-rev wrote:odyssey's are where its at because they're SEALED. If you want to flop them on their side, no problem. I checked at a parts store and a battery for a honda civic was like $90 or somthing, an odyssey has half the size and $106, with bolt on terminals
Thank you, your coupe looks sweet .hpmachine wrote:this is off topic but i really like the way your 240 looks with those mustang wheels
