If you honestly managed to decipher that from his post, you sir are a mind readerelwesso wrote:BTW the POINT of Techs post that 85k is still technically way overdue..
I think that would be an excellent idea, in a worst case, if you never used them, you could easily re-sell them.elwesso wrote:...If I was going to get a set of shocks that took months to get, id probably look into getting 2 sets, "just in case".....
Years of experience..... Miss Cleo, here I come!!!Falkdesigns wrote:If you honestly managed to decipher that from his post, you sir are a mind reader
1. I was using my brain to analyze the sensory data before and after the suspension swap. (Don't worry I understnd both the placebo effect and the expectancy bias.)2. I expected a more controlled ride with less body roll. 3. That makes sense4. That also makes sense5. That also makes sense6. BMW somehow avoids this compromise I've read.7. No numbers, just subjective opinion like he asked.Q45tech wrote: I can't tell the differnence
1.And what kind of precision test equipment are you not using to measure the difference.
2. Since suspension from best to worst can only affect the numbers by 5% on skidpad or track time...............don't know what you expect.
3.Vehicle weight on the tires and tires themselves are 90% of what's possible.
4.Understeer. oversteer, neutral steer is just the position of the steering wheel.
5.Struts are there to just SLOW DOWN the operation [cycling] of the springs and help maintain tire road traction..........nothing else.
6.To focus on improved handling one must almost totally disregard RIDE COMFORT ASPECTS!
7.Tell us what numbers [in steering wheel angle, G etc.] you are trying to achieve and we'll tell you how.
I think that's a reasonable assumption and would lead me to believe the suspension parts you replaced weren't the originals. I can tell you without a doubt there's significant difference in the ride quality between my 94 (stock, old suspension parts - 17" wheels/tires) and my 95 (Eibachs, Blues, etc - "newer" parts - 18" wheels/tires). The 95 is MUCH smoother and more comfortable.bullittandy wrote:I'm only referring to the improvements made by replacing WORN suspension components with new OEM. Not OEM versus aftermarket. I expected that my 213,xxx mile original suspension would not have felt nearly identical (subjectively) to an all new replacement. That's a reasonable assumption, right?
Answer, yes. I have had mine disconnected when I did my teins. (I forgot to reconnect after the job) I had no CEL. This is what I plan to do in the near future. I just can't justify spending the money on the T adjustable struts when I never use the option since lowering the car.paranoidjack wrote:
Here's a more legitimate question. The regular Q shocks, non adjustable...would these most closely resemble "normal" mode in my Q or "sport?" If "sport" is the answer, that is what I use 90% of the time and I had better get the more $$$ ones.
Thanks for all the input guys, as always.
I bought it at 194,000. They haven't been replaced by an infiniti dealer according to the history. The boots were completely disintegrated and they were the orginal style strut (not inserts) and the inside of the housing was stained from hydralic fluid.Rex wrote:
How many of those 213k have you put on the car?
