ahardb0dy »
https://forums.nicoclub.com/ahardb0dy-u30854.html
Thu Jul 06, 2006 5:04 am
Just don't do what I did, I replaced the knock sensors and harness, ( make sure you get the correct harness as their are 2 different ones depending on your date of production, I gave Joe the vin # on our 94 and received the wrong harness) than after getting the intake all back together I was tightening the LAST intake plenum bolt and the gasket must not have been sitting in the lower intake hole and when I tightened the LAST bolt I heard a crack, the sound of the aluminum intake flange cracking!!!!, It wasn't too bad but it cost me an extra $125 to get a new/used intake plenum ( thanks poppop) hopefully when it arrives and I install it the car will run better than it ever did before, also replaced the fuel pump as you did made a huge difference.
