its a 99B13@15yrszold wrote:hey whats year is ur GA16?
wouldnt it give u more hp? the only complaints on these "mods" is that they dont like to work on the dodge stratus, and the fact that all the mod is, is a 100k ohm resistor, but people are saying it increased there hp, i doubt it increases 20hp but maybe a little.nametakennow wrote:Ha, those are fake people that have it, or idiots.
What it does is tells your ECU that your intake temp is colder than it actually is. Your ECU then ups the fuel a little to compensate.
So, what do you have? A slightly rich engine with fewer hp and poorer gas mileage.
That's the short version.
The first two sentences are true. However, automakers don't reduce the fuel, they use timing and other emissions devices (EGR, precats, etc). Your car's a/f sensor isn't terribly exact, so to save money car companies tune cars to be rich so as to prevent accidental damage from lean conditions, as I said before. This "Performance Mod" does not increase anything other than resistance between the IAT sensor and your ECU. ECU ups fuel, and thus car runs richer. There will be no timing advance, the difference isn't big enough to cause that. Changes in timing reflect throttle position and rpm moreso than intake temp.idiot scammer wrote:Today's vehicles are required to produce less pollution. The way this is done is by regulating the ECU (the computer) to reduce emissions. This affects performance by reducing the amount of fuel, air and spark being delivered to the engine. The factory settings govern the ECU to mix a specific amount of fuel and air more favorable for emissions and not performance. Our Performance Mod increases your air, fuel and spark ratios to the optimum OEM level in turn you get -- Better Throttle Response throughout the RPM Range -- Increased Torque -- More Horsepower. Complete combustion means less wasted fuel!!
umm, i kno that last sentence wasnt used sarcastically, cuz from the way u inform, u dont sound like u kno much about what your talking about ether.B13@15yrszold wrote:what is said makes sense. fooling the ECU doesn do much good. having more fuel in da combustion chamber doesnt necessarliy mean more power. combustion is most efficient at the right ratio of air to fuel. if you have to much air, u might not get enuff power to push the cylinder down or the mixture might not ignite... and if u hav too much gas, it may not ignite properly. ur gonna end up wasting ur money. and its not a bad idea to read how stuff works. it does help u out for alot of things.
