liscence bulb burnout??
All things Altima Coupe.
elevate
Car: 2009 Super Black Nissa Altima coupe 2.5S
so i was trying to change one of the bulbs for the liscence plate light, when all of a sudden right as im installing the bulb it sparks and the other bulb wont turn on as well as the tail-lights. :ohno:
when i turn on the lights the hadlights work fine, but the liscence plate and tail-lights wont turn on.
the tail-lights only turn on if i brake....
any ideas on what happened?
much help would b greatly appreciated
thanks!! :wtf2:
DAAN.
Likely a burnt fuse and possible bulb (194 i believe)
lecros101
Car: 2010 A/C 2.5s CVT
I hope you had the negative terminal on the battery unplugged when you did that.
elevate
lecros101 wrote:I hope you had the negative terminal on the battery unplugged when you did that.
i dont think i did. it was only a liscence plate bulb replacement so i didn't think much of it...why :ohno:
780alti
Car: 2010 Nissan Altima 3.5SR
if your interior lights don't turn on either ( lights for buttons and radio controls) then you probably blew the taillight fuse.
just-blew-a-fuse-t498755.html
DiamondWVU
Car: 2.5
you blew a fuse. disconnect your negative terminal next time.
elevate
780alti wrote:if your interior lights don't turn on either ( lights for buttons and radio controls) then you probably blew the taillight fuse.
YEAA haha sounds about right. dang thanks lol
im gonna have to check that out :facepalm:
elevate
DiamondWVU wrote:you blew a fuse. disconnect your negative terminal next time.
haha will do diamond, kinda learned my lesson.
elevate
would anybody know how to fix, or how much it will cost to fix this?
Coupe12
Car: Nissan altima coupe. 2008, 2.5S
To buy a new fuse at WalMart?
lecros101
fuses wont run you more than 5 bucks for a pack of them
elevate
lecros101 wrote:fuses wont run you more than 5 bucks for a pack of them
ooo great. the suspense was killing me haha
so all i need to do is buy a new fuse and let someone install it, and all the light problems will fixed?
