Liquid Gasket KA24DE
pawndave
Car: 1995 Nissan Altima 2.4 liter
More questions... Im about to put my timing chain covers back on and it seems that Nissan calls out for part number, 999mpa7007 sealer, which nobody has in stock anywhere around here. Is there something that is universal out there that will work for this? I need sealant for timing chain covers, upper aluminum oil pan, lower steel oil pan. Im sure there is something that is made out there? Or does Nissan have a secret recipe for this magical sealer?
Thanks
alms24sebring
'04 Nissan Sentra SER SpecV
I think any RTV will do. I perfer to use the grey stuff instead of black because its way better and thicker. You should probly post in the 240sx/Silvia section
Dattebayo
alms24sebring wrote:You should probly post in the 240sx/Silvia section
Except for the fact that he has an Altima... :poke:
alms24sebring
lol fail... I stand corrected.
The point is that any sealant works. you can also find a factory service manual pdf here..
http://www.nicoclub.com/FSM/Altima/
and other useful info
table-of-contents-read-first-how-to-s-f ... 85258.html
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Hate to say it but Hondabond is a highly recommended RTV. MOst Honda dealers should carry it. If not Permatex Import Gray is what I used in the past with good results.
pawndave
Rev_D21 wrote:Hate to say it but Hondabond is a highly recommended RTV. MOst Honda dealers should carry it. If not Permatex Import Gray is what I used in the past with good results.
Ok thanks,
say, have you had any experiance replacing timing chain tensioners? I gonna be a little stuck when i get to the lower tensioner, it pushes against a long chain guide. I have heard something about pushing in the piston and insering a pin to hold it tight. Are you familair with this?
alms24sebring
VW also makes great RTV. Its some of the best stuff Ive ever dealt with IMO.
Rev_D21
Yes, I have heard of holding the tensioner piston in place with a pin. I have one I saved from my old Nissan tech days. It looks like a basic tack but has a longer pin with no sharp point. I bet a t-pin from a fabric shop would work just as well.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
For future reference you can post in the first thread you started instead of starting a new thread for each questions.
