Julio Bro! »
https://forums.nicoclub.com/julio-bro-u378.html
Thu Sep 26, 2002 11:52 am
Our cars have 2 compartments on the rear, each to the sides of the back, you can access them by small doors that lead to the light markers and, in the fastback, to the tire change jack.
If you have these compartments, put your hand in there and all the way to the bottom; check all along the bottom of the compartments. If you feel water there, your water drainage holes are clug. I don't remember exactly, but check that area from under the car, you can see the plugs. Push or pull them out, and extract whatever is clugging, in my case I had some cloth and papers in those compartments...which I didn't know will take in water if you drive through heavy rain or pass through a puddle. These things were rotten and in a pulp state which clogged these outlets, I had a lot of water there...some came from the antenna hole, because it doesn't seal like new.
Well, I hope this helps you...good luck.
