Liquid_cool's build thread (Finnaly posted!)
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
I thought id finnaly show my DD off a little,i normally just post to help others out so maybe this build can give others idea's..this is the build after my ka24de NA 225 to the wheels blew up on the freeway at 4am..lol..enjoy!
liquid_cool
THIS IS AFTER THE ENGINE BAY WAY REPAIRED AND SEAM WELDED FOR SUPPORT..THE PAINT IS (ford white)
liquid_cool
Becouse the paint was free and i had 2 gallons, i decided to paint it all white!..lol
liquid_cool
now for the motor...after the last motor desinigrated on the freeway with a huge fireball and parts flying everywhere...i decided to build a ka24de-Turbo..as most of you know, there is no cookie cutter kit to build a ka-t setup..so what you see is my best effort with a few 1-off mods to get the job done.
specs:
supertec 8.6:1 pistons
BC duel springs and Ti retainers
BC 272 cams (stage3)
ferrara+5 over valves
K1 rods
garret gt2860r turbo
Turbosmart raceport blow off valve
turbosmart manual boost controller
topfeed injector convertion
850cc denso injectors
here she is in the bay..a few views
gota love those hockey puck motor mounts :)
here is a vew of how i ran my coolant lines for the turbo..hope you can see it good enough.
this is a vew of the clearence gained by using hockey puck mounts to lower the engine by 1.5 inches.
this is a view of the clearence from the master to the manifold thanks to hockeypuck mounts,no melting that master resevior!
liquid_cool
here are a few more pics i took this morning, i wish i saved the ones while i was actually building this car..just so you all know, and i make this clear..i have crashed this car sliding probly 20 times and put her back together..lol..she looks rough..but drives strait as an arrow!
here is a pic of the fuel cell i have installed over a large hole, the old owner decided to drill 1 inch holes for mounting a speaker bok..he went throu the fuel tank.
this is a pic of the dash and the mod to the steering column , notice the tilt part goes allmost to the roll cage.
liquid_cool
did some more stitch welding yesterday on the inside rear area's due to some spot welds seperating from stress.
liquid_cool
i have to give some props to (Treadstone Performance) for there universal piping kit..it's some of the best quality aluminum pipeing i have seen thats actually polished and not coated..it's thick,light and strong..not soft like the ebay crap..and it was cheep!..think i payed $140. for the kit and i have tones of pipeing left over too!
liquid_cool
thought you all would like to see the welds up a little closer..here are a few pics..i droped some paint over the new welds to protect them from the winter conditions till spring when i repaint the inside via the roller method.
you probly notice the black ash marks, thats from the body glue being burnt away.
It's verry difficult to get that stack dime look with a high powerd mig, wish i had a tig.but im stuck with a miller 375 mig.
this is after some cheep spray paint,its so cold out atm it wont dry all the way.27 degree's
liquid_cool
here is the outside of the car...im planning to go (Rocketbunny) with her in the spring.
the Rims are (ACE) brand vintage 15lbs magnesium..came with the shell when i bought her.i have yet to see another magnesium set like these in Vegas.
liquid_cool
ill post pics of the suspention tomarrow ..i need to undercoat after the welding and it will give me a better shot with my phone :)
Razi
Car: Moo
KA-T setup looks good!
I wish I had money for nice fittings. I'm tired of rubber hoses.
liquid_cool
i make all my fittings razi..i have some -10AN line and fittings left over for a returnline if ya want it,ill make it..just pm me with dementions.
xFidelity240sx
Car: 1989 Nissan 240sx - KA24DE swapped
Holy poop this build is already incredible. I remember stalking your old build awhile back, if it's the same one anyways.
More more more more!! :ohno:
btw, how'd the NA KA blow up?
liquid_cool
xFidelity240sx wrote:Holy poop this build is already incredible. I remember stalking your old build awhile back, if it's the same one anyways.
she tossed a rod on the freeway at 4am omw to work..rod was bent like a ribbon, they were stock rods..225 to the wheels is all i could get out of her and it lasted 2 years pushed to the limits..extreemly decked head and block..10.5:1 pistons...15.1 cr...i think an injector failed and detonated..there was no shudder or anything..just a boom!..the rod cap took out my fuel line and the fuel cought fire via the manifold..hence the fire dmg..i had an extinguisher so the car was saved...the whole was so large throu both sides of the block , you could stick your arm throu it...blew the oilpan off, drivers side motor mount and the lower timing cover allso....i wasent even sad or remotly upset..it lasted 2 years, beat on, abused, raced dayly..i smiled knowing something better will come next :)
liquid_cool
well something new found tonight..with new power, comes new upgrades...i raced a 3000gt tonight in the middle of the desert on a country road (private road)..my brakes faded in 1.5 seconds at the end..time for an upgrade ..and my clutch had issues holding the power...i wasted his arse..but did it unsafely,thats not my style..got a B-Day comin up..guess ill buy me those 2 pot brakes insted of my rocketbunny bubble flares...safty first!
liquid_cool
This is for you RAZI..here are some better pics at the way i ran my coolant lines..and a elbow and flange i fabbed up to make it work.
the elbow was a PITA to make and get to fit properly but it worked great and looks legit.let me know if ya have any more questions...allso Razi, i do have 2 ends for AN-4 line..just no line..if you get the line i can make the set up ya want bro.
liquid_cool
here is a few pics of the front set up, i took care to take pics of the boxed in LCA's , its a good efective mod for strength..im running (Yamato Garage) camber,caster,rucas gear..i love them..super thick and high quality..to bad there out of biz now :( ..i have wicked iner and outer tie rods..you may allso notice that the bump stop was removed and modifyed for more angle on the LCA's...i allso run Godspeed hyper RS coils..for the price i got em at..$300 nib..cant beat it.
ill pop pics of the rear when i have more time to do so.
Razi
Car: Moo
That looks like a neater way to run the coolant lines, I think I'll redo em whenever I take my intake manifold out again.
I found a hydraulics shop that can make me some nice lines for fairly cheap, they're not AN but they'll do, so I think I'm good for now!
It's a shame Yamato is gone now.
liquid_cool
ya, it is a shame man...Yamato gear is b0mber stuff, and it was so afordable...it was a true loss to the 240 comunity when they went out of biz.
Olson_S13
Car: 240SX (S13)
This is weird to see haha. I am now owning this car. I took the cylinder head to a machine shop to get checked and saw your name engraved in it lol.
It's crazy to see the effort of the build.
liquid_cool
I'm so happy someone is getting use out of her.i gave her up due to a fight with bone cancer. My body just can't handle the stress of tossing her side ways. I you have questions, just ask.
Olson_S13
Car: 240SX (S13)
I'm not sure when you sold it. But I got it from a guy in Vegas that claimed to know little about it.
My biggest questions is the Fuel Pressure Regulator. The gauge reads 60 psi, but the Service Manual States 43 with no vacuum. Is that something you did?
The other huge thing is how you got the ECU tuned. When I did have this thing going the Air/Fuel Was reading around 14/16 at idle which I am guessing is the Fuel Pressure Regulator but without being able to take it to a tuner (no OBDII) I am a little guessing on what the culprit is.
I had the entire motor apart aside from the pistons and rods so far and I must say the pistons still look brand new. There was absolutely no build up anywhere in the combustion chamber.
Any info you have on the Fuel Press and Tuning would be invaluable. Having direct access to the builder is also a major relief.
Shadowa
Do you by chance still have this 240SX?? I'm Liquid_cools little sister and I've been trying to hunt the 240 down since he passed. I'd love to buy her back, or even just a PART of the car.
PapaSmurf2k3
Site Admin
Shadowa wrote:
Sun Jun 01, 2025 3:50 pm
Damn :(
I hate reading that.
Let me see what I can do to try and track down that user.
PapaSmurf2k3
Site Admin
I sent an email to the address on file. Let me know if you don't get it.
