Lino inspired look --
OwnerCS
Taking a break before I put on the last VC here tonight.
Sometime back our buddy Lino sent me a picture of a VH45DE with all the aluminium all polished up. Also earlier Wes and Heath suggested a brushed/polished aluminium look. So this is about as close to the picture that I can get – doing it all by hand without any help. I finished the water pump today.
I used a Dremel tool with like a jewelry polishing brush to clean up the aluminium finish.
This is a far as this puppy is going with me.. I’m ready to get it out of the garage.. :)
So here tiz..
Image .
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Wow makes me wonder what my engine could have looked like with a little love when i swapped it. Coulda just put a few more weeks into it and pretty'd it up a bit. GJ
Q451990
Wow!
:bigthumb:
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Wow - you did an AMAZING job. How many hours in?
OwnerCS
Most most parts had to be reworked two or three times before I got the brushed aluminum finish that I wanted.
Preparing the bolts for rust prevention and to have a consistent look seemed to take about 20 hours. The bolts were first cleaned in carb cleaner, then soaked in naval jelly to loosen any corrosion or rust, then polished or brushed one-by-one, soaked in carb cleaner again before a final acetone bath to remove any oils. After surface preparation, the bolts were sprayed with a high temp ceramic primer, then two coats of with a high temp gold engine finish, final ceramic clear coat, then after an hour, the bolts were baked in an oven starting at 170 degrees, moving up to 200, then a final bake at 300 to cure the ceramic paint.
The auminum components went through a similar process without the painting step. Actually baking ceramic paint seems to make it smooth out and produce a more glass looking finish. I will need to break in the car using 15 minute run then followed by an hour cool down to let the ceramic coating completely cure. The water pump was only baked at 150 for about 30 minutes -- I could still handle it because I didn't want it to heat up any bearings over the temperature that it could experience in a transport truck somewhere in southern AZ,
Here's a video of the process below with estimates. I think it takes longer for the final polishing step than the video shows. The part may have been placed in a vibratory polishing machine with some crunched up pecan or walnut hulls along with some corn meal.
My experience with polishing a part to have a mirror finish is wasted after a protective high temperature clear coat has been applied. After spraying a mirror polished part, its appearance would change and morph into a finish that looked like it had been sprayed with regular ordinary silver paint. I didn't want to use laquer as I know how it breaks down with petroleum solvents and after many heat/cold run cycles.
http://rinconrolla98.blogspot.com/2010/ ... ts-to.html
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
that is very nice. I'm glad my engine is hiding behind all those plastic shrouds :) What a labor of love, I wonder what it will look like after you move to the high heat of Arizona. What city you headed to?
OwnerCS
BadQ45t wrote:that is very nice. I'm glad my engine is hiding behind all those plastic shrouds :) What a labor of love, I wonder what it will look like after you move to the high heat of Arizona. What city you headed to?
Someday I would like to move to AZ -- though it might be 10 years from now. I've only been as far south as Sedona. I've got a bunch of friends from another car club that live in and around Sedona. I sure like Sedona with all the red rock scenery in additon to Flasgstaff and the Grand Canyon area. Winslow seems like a quiet place with Route 66 history -- though after a while I might get tired of all the serenity.
BadQ45t
Sedona rocks!! I lived in Phoenix while going to Arizona State, it is a decent place but the heat!! If you can retire or find a way to make a living in Sedona that works. My friends built a dreamhouse with views of Oak Creek Canyon, awesome place.
It sounds better then Little Rock, but then again I have never been in Arkansas!
BLACKonBLACK98
Car: Q45, LS400, STS-V
looks great. no issues with the painted bolt heads chipping when torquing them down?
OwnerCS
BLACKonBLACK98 wrote:looks great. no issues with the painted bolt heads chipping when torquing them down?
The bolt heads were painted with a high temp ceramic and put through an oven baking routine to cure and harden the finish. There was a little chipping that I touched up afterward. That's about only way I had to recreate the gold look that came from the factory.
