skylndrftr wrote:according to the 2008 G35x you can theoretically link ( I believe) 7 keys to it. given that you only are given two keys and the process is something you can do by yourself in your driveway this should be possible assuming that the systems are the same. I would try following the manual in one car with both keys then just the other on how to link multiple keys
Thanks for the reply, but I don't think there's any possible way for the intelligent keys to be programmed without the use of Consult III. The real question is if Consult III is able to program a single key to two cars - or more precisely if I key that is already linked to a car can have another car linked to it without erasing the initial link.
