link with working pics DIY lowering springs?????
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
D_Car777
Car: 2003 Infinity G35 Coupe
I have my tein lowing springs here now and I want to put them on but have no idea where to start. I went to the how to section and found the suspension link, but the pics did not work. I really would like to see them to help m do this. If anyone knows where I can get a DIY with pics, i'd really aoreciatie it. Thanks! Also, im kinda scared to install the rear springs because the back of the car is soooo low. I have 20X10's in the rear and have an index finger of room between the car and the tire.
joe603
Car: 2014 Durango R/T
The biggest problem you'll have is compressing the spring. The best bet is to take it to a shop and have them compress the spring for you. Taking the rims off will make the job 10x easier. This is one mod that a shop can do relatively cheap...
As far as DIY, I haven't seen much...search around this site or google it!
You should also get an alignment done after the install.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
