Lines for Boost / Oil gauge????
Edub1
Car: 89 240sx KA-T
Which vacuum line is the best for splicing in the line for my boost gauge?
Also, my oil pressure gauge seems to hook up the same way, where does this go?
Draginzuzu
For boost I used FPR vacuum line on passenger side of the intake manifold. Some boost gauges come with the small T thats perfect for it. Depending on which oil pressure gauge you have get a 1/8 bspt (someone correct me if im wrong) adapter to whatever size the sending unit is threaded for. Then take out the factory Oil Pressure unit and plug in your aftermarket one. The factory oil pressure unit is right below the oil filter. Disconnect the factory one or just leave it there up to you.
BadMojo
Car: 2007 Mazdaspeed 3
Yup, Nissan uses 1/8 BSPT while most gauges I've seen (Autometer, for instance) uses 1/8 NPT.
SPL has an oil filter sandwich adapter that gives you two (I think) BSPT ports so you can run oil pressure and temp without some weird configuration of T's and adapters.
Edub1
Car: 89 240sx KA-T
It's an Autometer gauge. So I have to buy what, something to convert from NPT to BSPT?
Florida240sx
Yes sir.Boost tap into fpr line. Oil gauge goes to where your oil sending unit is...or being you got a feed for your turbo thne you get a T one goes to turbo while other is for your gauge....
Edub1
Car: 89 240sx KA-T
All my oil pressure gauge has is a nylon hose and a rubber adapter for a vacuum line. No threaded fitting of any kind.
Draginzuzu
Is it mechanical gauges? Sounds like it. Try to get a electric one, to me its way easier to mount and pass lines threw the firewall.
Suicide.Veteran
Car: 93 Nissan 240sx
umm how about that bolt on the top of the collector? cant that be used for a boost gauge, or?????? cuz thats what I used for a faze boost gauge with a threaded fitting, and it works well.
