Thanks for the quick reply. Looking at the repair manual, it appears that these 4 solenoids you referenced are near the upper valve body whereas the "torque converter clutch solenoid valve" is in the lower body. I'm assuming the lower valve body is what you see when you drop the transmission pan, and that I will have to drop the upper and lower valve bodies to reach these 4 solenoids?VStar650CL wrote: ↑Tue Jun 06, 2023 12:38 pmThere's no single solenoid that controls the whole transmission, there are a group of them incorporated into the Valve Body assembly. Nissan generally calls the VB assembly a "Control Valve". There are four solenoids on the top side of the VB, three in a group and another one off by itself. The one off by itself is the Line Pressure Solenoid. See page AT-222 here:
https://www.nicoclub.com/service-manual ... 9%2Fat.pdf
From what I see in the parts drawings, you need to buy all four together in a kit, p/n 31940-41X09 or 31940-41X13 (supersedes).
Okay, thanks. Any special considerations when doing this? It appears that once you unbolt the "torque converter clutch solenoid valve" from the lower valve body, you can then unbolt the entire valve body (both upper and lower including the seperator plate) in one piece. Then I can unbolt the 4 solenoids I am wanting to change from upper valve body?
Okay, I see, thanks for the warning. Does it slide out from the top of the valve body or somewhere on the side? I was trying to get a reference of where exactly it is located in the AT Manual but, I don't see a visual reference to it.VStar650CL wrote: ↑Wed Jun 07, 2023 9:41 amIt's a shuttle valve connected to the shift mechanism that tells it which gear to be in. Once the VB is out, it can slide out of the hole and hit the floor. It's very precisely machined, so fumbling it can be expensive.
Okay, thanks for the information. Which page of the AT manual did you find the part numbers on. I have searched through it a few times unable to find them?VStar650CL wrote: ↑Thu Jun 08, 2023 5:51 amIt will be horizontal. It's usually a 4~6" long shaft that goes deep into the VB, but it's only held in position by the cam on the shift shaft which moves it in and out. Once you separate the VB from the trans case, it's just floating in the hole with nothing to hold it in if you tilt the VB the wrong way.
VStar650CL wrote: ↑Thu Jun 08, 2023 2:04 pmNot sure what you mean, they don't give part numbers in the FSM. InfinitiPartsDeal has OE parts diagrams, just feed it your VIN.
Ah, okay, I can definitely do that, thanks. I was just wondering how you found the part number for the 4 solenoids along with the superceded number?VStar650CL wrote: ↑Tue Jun 06, 2023 12:38 pmFrom what I see in the parts drawings, you need to buy all four together in a kit, p/n 31940-41X09 or 31940-41X13 (supersedes).
I was looking at the torque specs on page AT-222. I see that most of the bolts I will touching on the valve body have a torque spec of 7-9 in-lb, is that correct? I have a torque wrench that has in-lb increments and I plan on torquing everything according to the manual. I have used in-lbs before when torquing, but converting this to ft-lb that I'm more familiar I am getting 0.58 - 0.75 ft-lb. Just seems really like a really low torque.VStar650CL wrote: ↑Tue Jun 06, 2023 12:38 pmThere's no single solenoid that controls the whole transmission, there are a group of them incorporated into the Valve Body assembly. Nissan generally calls the VB assembly a "Control Valve". There are four solenoids on the top side of the VB, three in a group and another one off by itself. The one off by itself is the Line Pressure Solenoid. See page AT-222 here:
Ah, I see now, thanks. The solenoids came in yesterday. I'm going to shoot for this weekend to swap them out.VStar650CL wrote: ↑Mon Jun 12, 2023 6:40 amNo, you're reading that incorrectly. It's 7~9 NM. Look in the lower left, the figures in that diagram are NM (Kg/M, lbs/in). So its 51~78 lbs/in.
Hey Jay, thanks for commenting. I do have a plan for ensuring the bolts are tracked back to their location when removing them from the VB. Thanks for stressing this. The car has had a long history of "morning sickness" if we want to call it that in this case (maybe the last 5-7 years). The car has never wanted to shift into "D" when its cold but, would do so after it idles to warm up for a while, or was able to be started off in "1" or "2". The problem has gotten worse over the years so that even in the summer months after idling to warm up the car will have to be first shifted in "1" and driven, shifted in "2" and driven and finally into "D" after a few miles. Since "1" and "2" are the same gears as "1" and "2" in "D", I always assumed this had to be some type of electrical issue. I do admit changing these solenoids is a long shot though. A few years ago I dropped the pan, replaced the filter, flushed the transmission and filled it back up with factory Nissan Matic ATF. This did nothing. I am open to any suggestions. Let me know if you would like any additional information. I do have some codes written down at how that were picked up from a code reader quite a few years back. I will grab them as well this evening.3Q Jay wrote: ↑Tue Jun 13, 2023 1:10 pmjust catching up on this.
VStar has you covered, will be self-evident, but look for connectors inside the case/pan that need to be disconnected to drop the VB. also suggest using a piece of cardboard that you can put the bolts thru in the same orientation as you take them out (they are different lengths). Replace the metal strainer and clean the magnets.
But looking back to your original problem statement, it's not obvious to me that the solenoids are the root cause. Could be--but not certain. What other maintenance and history can you provide?
Hey Ryantzer, thanks for posting. I do have some codes that were pulled off of the car from years back. Let me grab those and see if any are potentially related to the issue. If not I can have a code check run on it and I'll post the findings here. Would this be done at your local auto parts store? I believe my local auto parts store will do a free code check.
Okay, I will do some research and post what I find. I did have a diagnostic check at an Infiniti dealer about a year ago and they reported "DTC P1492 STORED FOR THE PURGE CONTROL VALVE SOLENOID". I don't see that code in the transmission repair manual. Appears that it might be related to the evaporator.Ryantzer wrote: ↑Thu Jun 15, 2023 5:35 amCodes from years ago won’t be relevant today.
Your local auto parts store is probably not going to have the ability to pull anything more than basic OBD2 codes with their code readers. It will likely take a more advanced scanner, or there may be procedures in your factory service manual to pull codes without using a scanner. Once you’ve got codes the FSM will also have the diagnostic procedures to follow for them.
I have a copy of the owner's manual in the car. I downloaded another copy (link below). I don't see a way to self check codes. All I can find is where it says that the ECM stores codes for reference by a technician.Ryantzer wrote: ↑Thu Jun 15, 2023 6:26 amLocate a copy of the Nissan factory service manual - if you're planning on doing any work on your vehicle it's the best source of diagnostic and repair info. I think I found mine on Q45.org, but some capable Google-fu should turn up a downloadable version if yours isn't there.
Okay, I see some of the self diagnostic procedures in the transmission service manual now. It sounds like the TCM codes are overlapped with the OBD-II and stored there as well. I will check the codes and run through the self-diagnostics and post back what I find.Ryantzer wrote: ↑Thu Jun 15, 2023 6:26 amLocate a copy of the Nissan factory service manual - if you're planning on doing any work on your vehicle it's the best source of diagnostic and repair info. I think I found mine on Q45.org, but some capable Google-fu should turn up a downloadable version if yours isn't there.
