Here is the issue. Most older domestic muscle cars have a master cylinder with one line that comes off of it and splits into two for the front brakes. A line lock kit locks that one line via a solonoid valve and doesn't allow the fluid back.
The S13-S14 and Z chassis use 3 lines off of the MC. 2 for the front, 1 for the rear which splits.
So its bit harder to do with our cars. But you can get two of these here (
http://www.jegs.com/p/B%26M/751616/10002/-1 and make you own kit. 2 Solonoids, fuses, switch. The only issue I see is that you will probably need to have adapter bushings made to go from the thread on the Solonoid to the Nissan metric thead pitch. It would also need the flair fitting.
