g37alberta wrote:It is a 2008. It likely has something to do with the oil mainenance light. It didn't get reset last oil change because I got it done at a Fast Lube place. Also I use Mobil so I go longer between changes. I am sure their is no problem so I just want to reset the computer then drive it to a mechanic. Thanks
Mine didn't get reset either at the local Infiniti dealer. Didn't put into 'limp mode'.
Now about those daylight running lights. When you stated 'hooked up' what was needed to do that to the U.S. model?
Also difference in the speedo?
Perry
