fitch9014 »
https://forums.nicoclub.com/fitch9014-u32378.html
Sun Nov 12, 2006 4:58 pm
it only does it under load, right? check the injector dropping resistor, i've got a long story about this and basically, if the engine loads up on boost and there's any interruption in flow to the resistor you'll get the symptoms you've described. at least, i did.
and i'm not totally sure about this, but i don't think in stock form this car has a limp mode. it might throw codes and that would make it run like a three legged dog, but being that it's obd1 they'd be pretty limited, however i could be wrong about that. basically, if there's something wrong, it just needs to be replaced. but like i said, not totally sure about this. hope this helps.
