I decided last winter to buy what was needed to eliminate the strut top-out I was experiencing almost daily. The road from my house to my work are not in good shape and I wanted to so something about it before my strut disintegrate !
I tried last saturday to take a few pictures to better illustrate how I have decided to do it. There is other ways, but I like mine for different reasons.
1) I used adjustable clevis so I can move the adjustment of the strap if I need it or if I change the setup or suspension. Since At the time of doing this I knew I was going to add a spacer later in the year, I knew It would be a piece of cake to do so. If you have a fixed setup, then you need to either re-weld or change your straps...
2) I welded a plate on the inner fender of the pathy cause I feared the metal sheet of the pathy was not going to be strong enough for the long run if I just welded a small surface mount on it... So I welded a plate, then welded the surface mount on the plate, giving more strength and area to the mount.
I bought my stuff at Pacific Custom ( http://www.pacificcustoms.com ) Great service and fast delivery, no mistakes...worth mentioning these days..
The parts I used are the following :
1) CHROME STEEL ADJUSTABLE CLEVIS FOR LIMITING STRAPS - MADE IN CHINA
Part Number: AC510050C
Price: $35.00
2)WELD ON FORGED MOUNT FOR LIMITING STRAP CLEVIS
Part Number: AC510050CV
Price: $10.00
3) BEARD 13 INCH LONG 2 PLY BLACK SUSPENSION LIMITING STRAP WITH 1/2 BOLT HOLES - MADE IN USA
Part Number: RA17113
Price: $24.00
In my setup, a 13Inch strap was limit a bit and that's why you see the adjuster all the way to the minimum. But since I will be adding a spacer this winter, It will go down 1 inch and will be perfect. Be advised that straps do stretch a bit. I would recommend a 12inch for a regular pathy lifted with ac springs but no spacers.
The bottom was made from a welded piece of steel that was bent a bit in order to have a direct line with the upper mount so that it pulls in straight line.
Here's a few pictures... If you have questions, don't hesitate. ha yes, almost forgot... gone is the bang of top out.. now I don't hear anything.
General view:
Upper mount:
Lower mount:
.Hopefully this will help clear the many questions you guys may have about this mod.
S.
