DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Tue Nov 20, 2007 3:30 pm
I've got my rb20 apart right now. I've always read how poorly the stock head flows, on the aussie forums and such. Although, I really cant find any major flaws with the factory head, I admit, the valves look very slightly too small, but how large of valves do you need to release 333cc's of exhaust? I'm convinced there are only 2 problematic area's of the factory rb20 cylinder head.
Camshafts: Would increase the efficiency of the (maybe) small valves. Considerably higher lift (9mm+), and whatever duration you prefer, to determine the idle you're after (or lack thereof!) Seriously, stock cams work well for a stock motor. 7.5mm lift? 240 duration? Thats weak sauce. On another note, "Forced Induction performance tuning" By Grahm Bell, claims I believe a 18 hp gain with *no* loss in torque from a properly adjusted set of Cam gears. Pretty much every rpm past 4500 I believe gained a considerable amount of power. I'll write up the article if more people are interested in this (they do 3 dyno pulls with 3 different setups on the RB20). Seriously, buy the book, its amazing. I suggest reading "Four stroke performance tuning" first.
Lifters: The only other thing I'd worry about in the head is getting cams with a lift that would overwork the factory hydro lifters. I personally dont think its worth the effort, and valve adjustments, to upgrade lifters, but I'm not going for world record horsepower, and will never get a set of cams that recommend solid lifters, in favor of simplicity.
After that, if your still wanting more power, and choose to do so by way of increasing the RPM, valve springs may be in order, but I cant say that from experience.
Any comments?
