limited slip
funkydrewster
Car: cars, art
how can i tell if my car has a limited slip differential??:oface
kyle1911
Car: 1989 240sx xe coupe
burn out and count the lines:D
eddiec
Car: 91 S13
lift the rear wheels off the ground. spin one side. if both wheels turn in the same diredtion then thats lsd. if they rotate opposite of each other then its an open diff.
gyfer
Originally posted by eddiec "] if both wheels turn in the same diredtion then thats lsd.
Not totally true. Not all LSD will do that.But this is one of the way to test it.The other method is to check the "orange label" saying some silicon modifier are use in rear differential.
