Limited Slip...or not
jlmphoto
Car: 1992 Nissan 240SX SE & 2003 Nissan Sentra SE-R SpecV
How do I tell if my car has a Limited Slip diff? Sorry if this is a repeat.
biggie
Only way it would be there from the factory is if you had ABS (and usually on a hatch it would have HICAS as well). The Diff would have an orange sticker if it was all original. Most likely you do not, unless it was swapped in by someone else.
Supposedly for the VLSD, if you jack up the rear, and spin one wheel the other one will spin the same way if it is VLSD.
jlmphoto
Thanks, that is what I thought...no LSD. It doesn't have ABS either...which is fine by me. I guess I'll put that on my wish list. Thanks again.
DanThaMan
Car: 1993 240sx
no no no...When jacked up, both tires will spin the same way if Limited slip, Opposite directions if its open diff.
jlmphoto
DanThaMan wrote:no no no...When jacked up, both tires will spin the same way if Limited slip, Opposite directions if its open diff.
Either way...no ABS...so no LSD.
DanThaMan
Car: 1993 240sx
I would double check bud, Mine never had abs and has a limited slip. Just light those tires up and see how many stripes you leave :chuckle:
biggie
DanThaMan wrote:I would double check bud, Mine never had abs and has a limited slip. Just light those tires up and see how many stripes you leave :chuckle:
If sitting straight an open diff can still turn both tires.
jlmphoto
I can't wait to burn both tires!...whatever kind of diff I have. :dblthumb:
biggie
Easiest way to tell OEM Open vs OEM VLSD would be to look at the diff.
VLSD has a bigger back cover.
jlmphoto
You said earlier it would have an orange sticker if it was factory lsd. Where might that be located?
lenso
Car: 1993 240sx hatch
jack the car up and spin one wheel by hand. if the other wheel spins the same direction you have a lsd. stickers can fall off.
jlmphoto
Cool...gotcha.
biggie
Yeah, most stickers have probably been long gone.
But again without ABS it wouldn't have been a factory option, another owner would have had to put it in. So its doubtful.
Buck01
Car: 1996 240sx SE (Kouki)
Another option is jack the rear end up and spin one of the tires by hand and is the other side spins the same way u got LSD,..
laxands13
Car: 93 240sx Hatchback - Sold and missed
80 280zx - sold
83 Honda Civic Wagon - Current DD, soon to be CA16 powered
Lol, thats like the 5th time thats been said ^^. Very true though, i actually am gonna have to test mine soon too
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
That "jack it up and spin the wheel" thing is hit and miss. If you leave the trans in neutral, depending on the conditions of various bearings in the drivetrain, both rear wheels might spin the same way. So if you do the test, make sure its in gear. With an open diff, the rear wheels will definitely spin opposite directions, and it''ll be pretty easy to spin them. With a Nissan VLSD, if its cold and/or worn out, you might still be able to spin one wheel and have the other spin the opposite direction, it'll just take more effort to spin them. This is because the viscous coupling doesn't reach full lockup until there's torque applied and the fluid heats up. Were still agreed that most likely you don't have an lsd, but this is the proper explanation of how to test for it ;)
or you could just go and light them up in a brake stand :chuckle: that'll tell you for sure...
